2 ohm or 4 ohm bridged?
  • 2
bilug
I've got a HiFonics ODIN VII....
I'm running it 4 ohms bridged mono and getting 240 watts out of it. It's running 2 kicker 8" subs and sounds awesome.
My question....would there be any advantage to running each channel at 2ohms? The amp would still put 120 watts into each speaker, but would it feel or sound different??
well, 2ohm stereo is always 4ohm mono (well, typically it is)..it will put slightly more strain on your amp, but i suppose from a rise point there should be an increase perhaps. But i think it would be inaudible and therefore pointless
It also lowers the amps efficiency and raises the current draw.
5
689
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
491
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
bilug
bilug
Seattle, WA
kr15
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
