2 SA 8's with a aero port box
  • 4
Hello, this will be my first box build. I designed a 1.33CU box last night. Once i calculated the port length for 1 6" aero port it said i needed a 41" port length! Now i am very confused and could not find anything useful online. Any help for a newbie?
Thanks,
Nolan
I built a similar box about 3 weeks ago heres a link to thread http://www.caraudio.com/forums/miscellaneous-car-audio-reviews/610452-cherryman-custom-enclosures-dual-sundown-sa8v2-crossport-box.html If you want to use a aero in a straight line you will need a box at least 48 inches long. If you decide to put bends in your aero your efficiency will decline and any advantage gained by using a aero will start to decline. A aero this long will need a considerable amount of internal bracing to hold t up. At these lengths aero's loose their appeal and limit design options over a traditional port.
1.28ft^3 per chamber gross
41" port = .42ft^3. 4x3
Fb=32. F3=28
.78 ft^3. Net volume after all displacements
Outside dimensions
43x11hx14.5 deep.
Ohh, i figured i really screwed up my math somewhere. So is it possible to use an aeroport with these at all. I have a very limited amount of space in my subie and can't really go any longer than 35" long.
A 4" would work perfectly
a 6" aero is a tadddd bit on the high side for port area, which is why you need it so long to bring down the tuning
I'd go with a 3" aero, maybe even 4"
A 4" would work perfectly 9.44 sq In per cube it would need to be 18.8 inches long to tune to 35hz total length flare to flare.
Okay, thanks guys. Now Sundown does recommend a 8-12in^2 port area for each e8, a 4" port would be about 14in^2. is that okay because it's an aero?
7-9in^2 is what is usually recommended for an aero they are aittle more efficient then a slot port or straight pvc which is usually 12-16in^2. Your enclosure will be 1.33 cu ft so 1.33/12.56=9.44in^2 per cu ft. Don't forget to take into account the displacement of the port from the total volume of your enclosure as well as the subs displacement.
Are you going to do actual aeroports with flares on both ends? I’m running a single 4 inch aeroport on my little 750 watt 12. It has flares on...
And you failed to mention airspace of the box or the sub and power you were running. In 89 most subs were extremely low xmax meaning very little...
14
Yeah, saw that too, was like ??? wtf! They do know there stuff, I usually just roll with it!
13
You could try to make the port longer, but there might be other reasons with the box won't extend lower, or even the sub. You'd have to reverse...
726
While that program is pretty neat, it assumes you know the values. I was just recapping the numbers you provided. RS recommends the following...
4
900
dagormz
dagormz
United States
dagormz
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
