box help
  • 3
i would download torres box calculator thats what i use i am getting substantially different numbers then the other poster. also if your going 2000+ rms orion rcommends an enclosure 3.05cu ft. im sure you could fudge that a bit . i come up with a port 18.5x6.5x27 net volume of enclosure is 7.98ft3 tuned to 32.14hz port area per foot is 15.07in2 this is with an extra baffle and taking into account the displacement of the subs while leaving you .25ft3 for bracing.
That's definitely more accurate. My bad op. Threw the numbers together too quick.
where should the port be on the left side or driver side and subwoofers other side that Port seems long
is the enclosure going in a trunk? if so it doesnt really matter. if it is going behind your seats i would do the port on the drivers side and mount the subs as far away from it as possible. your also bridging an amp to each sub make sure they are gain matched or set to the same voltage.
I think you're gonna have to get good with fiberglass or something, or find someone with a 3d laser scanner that can 3d print or mold you some...
7
I've used that driver and the ported box is closer to about 2 cubes. We did 1 in a stuffed/sealed 1-1.25 cubic foot box, stuffed with 1 lb of...
821
Absolutely. I am always learning and think it's probably impossible to stop learning. I appreciate the advice and don't doubt for a second the...
56
4K
People didn't like ported boxes because the port noise and needing a bigger box. Therefore, instead of 1-sub in a ported, they would go with...
30
3K
spliffc
spliffc
North Carolina
snyderd758
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
