2 subs, 2 amps, and 1 box??
  • 3
pentaX
First time I ever thought about this setup. Major problem is, if subs were side by side (width of hatch area) there leaves absolutely no room for the BIG ass amps. Is it possible or would there be too many problems? They will be ported...
The subs: JBL W15GTi's. The amps: JBL BPX2200.1's.
Current designs call for 4 cu/ft, 30 sq/in tuned at 28Hz. Would it be wise to say, if it was 1 big box (8 cu/ft after displacement) the port would be twice as big, but only a little bit longer to compensate?
Thanks
Additinally, no need to reference "max" anything as those specs are useless. Most of know how to look at specs for a given speaker, amp, HU, etc...
446
I think Taramps has a 1200.1 @1 ohm amp out there too or an 1800.1?? But for the price of an 1800.1, you can find a decent 2 k for the $ or a 1500.1
11
Need to know your setup. Just curious, before you connected it, did you check your resistance for your subs?
pentaX
pentaX
Denver Colorado
Nikuk
Mr FaceCaser
    May 20, 2024
Mr FaceCaser
    May 20, 2024
