2002 chevy impala
  • 3
Well from what I researched there are 3 different kinds of kits you can get.
One where you loose factory settings (without bose and onstar)
One where you keep factory settings (without bose and onstar)
and then that one where you wont loose anything and it will work with bose and onstar
You have that exact same kit? Or are you confusing the kits?
mine did it. so i got the Walmart kit to retain chimes. My SQ dropped terribly.. lost thefactory amp. I have RSD's, 2channel MTX amp, pioneer 6x9s, and alotta new wiring goin in soon.. sq really does ****, serious
Nice, well I think they will blow away anything you have running on your puter for sure. I've had good luck with the NVX components, hard to beat...
16
I have a 2001 Nissan Sentra GXE and I've never found one. The loc is the next best option
I had a '99 Chevy Venture with the 3.8 and buddy had one with the 3.4. Any of those engines including the 3.9 are known to leak coolant at the...
12
789
You can raise the back sea approx 2 inches and get a front firing enclosure for two tens in there ported center. Other than that. Atrend makes a...
5
A lot of guys say I'm going low-end on cost but I see a lot of guys recommending just as cheap or cheaper products. Like MESO-6-5-3WAY-COM //...
13
moptopklee
moptopklee
Union, Ky
RipDaJacka
Decebal
    Jun 10, 2024
