2008 G6 Steering Wheel Control wiring
  • 2
Manuelxr7
Hi! new here so Not sure if this is the right section, I have a 2008 G6 GXP, and I installed a 2010 G6 steering wheel so I could use the DIC buttons on the 2010 wheel with my 2010 Gauge cluster I installed. Everything works on the wheel except for the "Info" and "Enter" buttons. I have attatched diagrams of my 2008, and of a 2010. It looks like I need to add a wire/relay where it says "Instrument cluster 1358 D-GN/WH" on the 2010 diagram. I am not very good with this stuff, so even if someone can just tell me what needs to be done I could take my car to an installer to have it done. (I also have had my BCM programmed to 2010 specs)View attachment 26539410View attachment 26539411
where are the original info and enter buttons for a 2008 wired to? if a 2008 didn't have either of those inputs, then neither does the 2008 computer. adding programming doesn't add inputs. a relay won't work. the 2010 looks for specific resistances to determine what button was pressed.
The 2008 doesn't have those buttons on the steering wheel, it has them on the radio. My computer is fully setup for it to work. WAMS did it. I was told that I need to "add a green/white tracer wire from pin 1, circuit 1358 to IPC cavity B3" and that's all they told me, to me that is in a different language lol.
I am installing a Maestro SW, steering wheel control in a 2008 Honda CRV. When I flashed the unit it gave me instructions stating that I needed...
And it works great with android phones, you can connect, and what can you say about android radio tape recorders are now leaders in functionality...
ie just used a new adapter because adapters ignition wiring wouldn't keep constant, works fine now and stopped sending sensors off, never had the...
9
thanks for your time in replying and the effort you have obviously gone to, my radio only has just one single wire for the steering wheel control...
4
Not enough information. Some remote units are radio specific while others are stand alone.
Manuelxr7
Manuelxr7
Turlock, CA
Manuelxr7
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
