dpx7200dab Steering Wheel Control
  • 3
jamesmckie
CarAudio.com Newbie
UK
Hello I have a Kenwood dpx7200dab trying to retain steering wheel controls (ford focus 2008) vol up/down and seek up/down
I have 2 wires from the cars SWC... control and earth/ground I presume, out of the dpx7200dab I have a wire for steering wheel connector, have tried connecting this to the control wire and joining the SWC earth/ground to the black (earth/ground) wire in the stereo harness but it's not working, what am I missing?
thanks, James
Are you using an adapter? It sounds like you just installed an aftermarket head unit, and are trying to make it work to your factory steering wheel controls. You need a steering wheel control adapter. (I might have this backwards), but your new head unit has digital controls to the steering wheel. Your steering wheel controls in that vehicle are an analog signal, and you need the adapter to convert them. There's a few brands out there. Here is one of the big ones.
If you have Amazon, check their for what I have found is the best price on these.
thanks for your time in replying and the effort you have obviously gone to, my radio only has just one single wire for the steering wheel control, no 3.5mm input and my car has but only 2 wires going to the controls, maybe it's that you mention about one being analogue and one being digital I really don't know but I didn't see anything on the links that I felt would work with this particular Kenwood stereo
Not enough information. Some remote units are radio specific while others are stand alone.
Did the instructions on the back of the main module not work? They are vague but give you a general procedure.
Update: I emailed Atoto support. They are asking me which wire in this Simple Soft CAN BUS controls the steering buttons? If I knew that, I...
That might depend on the head unit. Some can use a 5 amp fuse, some a 10amp, some a 15amp fuse (if / depending on how much it's powering the...
5
jamesmckie
CarAudio.com Newbie
jamesmckie
UK
jamesmckie
winkychevelle
    Apr 27, 2024
audiobaun
    Apr 27, 2024
Latest topics
