2011 Ford Escape - SQ Build
Donnie W
18
Ontario
I figure I'd post the start-to-finish build and install in our 2011 Ford Escape.
Here's my wish-list:
1. New head-unit. Touch screen, supports USB, iPhone, Bluetooth.
2. New speakers all around, components up front.
3. Subs.
4. Amps for above.
5. Reduce unwanted noise.
Here's my requirements:
1. One through four above.
2. Minimal modification to vehicle.
3. Minimal loss of space.
4. Retention of all factory audio/phone features (SYNC, SWC, etc).
5. Fit within my budget.
I'm not a dreamer, not a butcher, not interested in competition or otherwise displaying (dare I say 'showing off'). This is a one of our daily drivers. The car needs to sound great, look clean/professional, and remain practical.
There are some challenges in this car to be sure. I already know SYNC is a pita to work around, and the room for subs is not exactly great. But I'll do what I can and document it along the way so that others with these popular SUVs get an idea of what their up against. I am not all an expert in this field, rather I work in high-tech forensics. So bear with me as I build this out.
Speaking of what I'm up against, here's the factory dash and rear cargo area. This is what I have to work with.
Factory deck, no sub, no amps. I DO have the steering wheel controls (not shown)
Rear cargo area.
I picked up a set of Hertz component speakers (Energy series). The set includes a 6.5" driver and 1" tweeter, along with the corresponding cross-over. This is the first goal in the build, ditch the front cans.
I didn't take a photo of the stock speakers, however, here is the void left from the speaker. Contrasting the stock hole is the outline of the 6.5" woofer. I also replaced the stock wiring, which is no easy task given the wire harness from door to body:
The inside of the door panel looks like such:
First order of business was to create a mounting ring. Cut, pre-drilled, and beaded with acoustic caulk:
I nice clean strip of high-density door seal and it's ready to mount:
A little bit of black spray paint to finish the MDF ring, mounted the speakers and voilà!:
Apologies, going to do some catching up here as I just joined the forum after folks on a Ford forum suggested I post here as well. Sounds like they like this place //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I've about two weeks into the build, so I'll bring the thread up to speed.
So while I poked away in the doors I noticed Ford installed 3 cents worth of foil covered tar in some kind of attempt to knock down the road noise:
I kind of expected as much so I ordered up some acoustic treatment from the good folks at B-Quiet. I'm not about plugging people for the sake of business, rather I mention the people who treat me (and hopefully others here) well. B-Quiet sent the stuff fast, included a nice roller and even called to make sure I got my order.
Install of that stuff to follow.
Got the doors done last night. Two layers of B-Quiet Extreme.
I also placed some B-Quiet on the door panel itself, particularly around the speaker area. Should give it a little more mass.
Next up, I decided to work on the tweeters in the lower A-pillar.
Drilled and touched up with the Dremel.
Tweeter in place. Only thing I did after this was add a couple spots of hot-glue to keep the tweeters in place, though they were already tight fitting.
The finished product.
618
Probably the adapter brand. Other users have found that the pins do not coincide with the factory pinout guide. They have solved this by pulling...
HUGE thanks to everyone who contributed in here to helping me determine my amp was the issue. You guys were great. I now own a multimeter which...
53
6K
Hi crew! I’m reaching out for some help. I have a 2011 Fiesta SES and have all the parts needed for a conversion to Sync 3 except the harness...
Donnie W
Donnie W
Ontario
ToxicAcoustiks
