2013 F150 XLT Supercrew Build Ideas
  • 1
mvrk
Getting ready to purchase my XLT Supercrew 4WD with EcoBoost and will be gutting it the day I bring it home to do my install, if anybody has had any experiences with the equipment I will be using I would really appreciate reviews on it!
Here's what I will be using:
Signal Processing:
Rockford Fosgate 3Sixty to maintain factory head unit
Arc Audio KEQ5
Amplifiers:
RE Audio ZTX800.4 (mids/highs)
RE Audio DTX1600.1 (subwoofer)
Speakers:
RE Audio SR 6.5C Components (front doors)
RE Audio REX 6.5 Coaxials (rear doors, mostly for fill)
Subwoofer & Enclosure:
RE Audio S EXV210D2 in a Fox Acoustics vented enclosure (1.25 cu. ft. airspace tuned to 36 hz)
Accessories
Second Skin sound dampening
12 ga. wire to subwoofer
16 ga. wire to mids/highs
4 ga wire to amplifiers
Scosche adapter plates for mids/highs
I plan to remove the carpet from the rear wall of the truck and mount a carpet matched piece of MDF cut to fit the rear wall where I will mount my amplifiers, crossovers and 3Sixty.
I am going to wire my woofer down to 1-ohm as the DTX1600.1 is class D and 1-ohm stable, this will feed the sub 750 watts RMS.
I am hoping I can mount the KEQ5 inside the center console but if not I will probably mount it between the console and the cup holders if space allows. I want the truck to look as stock as possible inside, but sound like a rock concert. Also, I'm hoping the absence of big DVD screen in the dash will shy away potential thieves which is why I am really hoping I can mount the KEQ5 out of sight.
If anybody has any install tips, advice or reviews(good or bad) on any of the equipment I've listed I would love to hear it!
Have a great weekend fellas.
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Anyone? Anyone? Looking at the audio control d 6.1200
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Excellent for good sound stage and imaging, don't expect it to move your mirrors or anything. Honestly with what you're trying to do just doing...
12
mvrk
mvrk
folsom, ca
mvrk
