2013 Hyundai Veloster
  • 2
Manchesteruntd
Finally finished my daily driver! Everything is swapped out and sounds great! I maintained the factory head unit (I plan on adding a JL cleansweap). both amps are mounted under the seat where they are mounted to a piece of MDF that is bolted to the car, utilizing the factory bolts. The JL XD 400/4 is powering a set of JL C2 650 coaxials in the rear, and a set of Rockford Fosgate T1650s (I plan to remove the RF components and replace them with JL C5s). I routed around the factory speaker bracket of each speaker to create my own bracket out of MDF and utilized the factory mounting holes. the JL G1700 is powering a JL 12w3v3, which is in a custom fiberglass enclosure I built. all the wire is Stinger HPM, the fuse holders are all stinger as well. View attachment 26547003View attachment 26547001View attachment 26547002View attachment 26546999View attachment 26547000View attachment 26546997View attachment 26546998View attachment 26546996
There are a couple that SMD has tested, around $20.00 that should take the wattage from most any HU. If you are tapping into the speaker wires...
Anyone? Anyone? Looking at the audio control d 6.1200
in advance i already a have a sub skar zvx hooked to a 1500 watt ab mono so take into account there will be a sub may or may not change out the...
Excellent for good sound stage and imaging, don't expect it to move your mirrors or anything. Honestly with what you're trying to do just doing...
Manchesteruntd
Manchesteruntd
Los Angeles
Manchesteruntd
Decebal
    Jun 10, 2024
Decebal
    Jun 10, 2024
