a long break for many reasons - mostly other projects. Since I have the second HU, i have a clean source. But a little motivation got me back into it.
Step 1 is to add wire to the Audio Input pins on the HU amplifier IC. This is the easiest place to get a low-distortion signal before the internal amplifier and this signal should already be passed through pre-amplifiers. Doing so required 30awg "wire wrapping wire" (OK Industries R-30W-0050) and a 0.03 in. soldering tip.
An LED magnifying lamp helps as well, and some of the pics are through the lens.
In all, I tapped 7 places.
Pin 14: FL in (left front audio - unbalanced)
Pin 15: FR in (right front audio - unbalanced)
Pin 12: RL in (left rear audio - unbalanced)
Pin 11: RR in (right rear audio - unbalanced)
Pin 13: AGND (audio signal ground)
Pin 25: B REM (remote turn-on)
Pin 22: MUTE (suspected telephone mute)
odd-numbered pins are in the front and easier to access (you don't have to remove the board). even-numbered pins are in the back and you need to remove the board to get your soldering iron in there. Removing the IC isn't necessary. This took about an hour start to finish and i did reference my instructions at the start of this thread for the order in which to disassemble. //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
I may have a concern with running parallel loads on the pre-amp on the board, but the opamps should be fully capable of supplying twice as much current given how little current feeds an input stage (typically 10,000 ohms).
Next steps (tomorrow evening) include adding small heat shrink up to the connections for protection. Then I'll connect the wires to some RCA pigtails (pulled from an older Alpine head unit that was for parts). And the remote and mute will need a connector added. i can cut into the top cover to notch for the RCA pigtails.
all wires connected
front pins
rear pins
RCA to be added
once I have RCA outputs I can run them directly into my 9887 AUX input and also RTA the output (what we really are interested in). I suspect the output will be fixed (non-varying) because most amplifier IC's have a volume input.
