2014 Accord Sport SQ Build keep_hope_alive
Dude dont know he is talking to the King of all things audio related does he ?
Perhaps keep hope alive can help him with that dsp //content.invisioncic.com/y282845/emoticons/biggrin.gif.d71a5d36fcbab170f2364c9f2e3946cb.gif
Wow, glad you got it back, even a bit banged up... I can't guess how you'd make scratches like that and the hole underneath, off-roading in bushes or something? Was it left abandoned or did they catch the thief?
Glad you got it back! It'll probably take some time to determine what all was damaged and if you keep it. Hopefully it all works out after all the time you have invested.
-Eric
Sent from my SM-G930R4 using Tapatalk
I have a cavity in my rear hatch of my 02 Ford Escape. Im buying a case of OC703 for my 4 doors and imagine Ill have some left over, would this be good for the hatch door or am I better off with stuffing every square inch with the denim fill? Ive already stuffed all the cavities I could with denim fill in the cabin floors and pilars, laid a layer of the sound deadener, radiant barrier, MLV and the carpet. It sounds all right, but I expected better. I havent done the doors yet so Im hoping thats the reason Im not impressed. My plan for the doors is deaden, ensolite, OC703 wrapped in 1 mil, abs panels to close off holes using threaded rivet inserts to bolt it down, more deadening, and hopefully have room for some MLV hung from threaded rivets. The panel itself Ill deaden and/or ensolite if I have any left over.
**** bro. Exactly why I'm about to get an alarm with starter killer. Hondas are still highly stolen and I just got 18" rims and my stereo put in. That's my biggest fear thus far.
Mine has that already, but they took the keys from the garage.
Rich V.
I thought you had two amps?? What happened to the wood that you were going to have H.depot cut out?? Looks different to me for some reason. Do you...
This is the max fuse sizes for the knu wire. The kca 4awg kit can supply 100amp to the rp1200.1 but it won't have enough left over for the rp75.4...
26
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
831
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
keep_hope_alive
Premium Member
Acoustics Engineer
keep_hope_alive
Quad Cities, IL
keep_hope_alive
