2014 Ford Focus Titanium: Stereo Upgrade Disaster..need help
tcwave
Hi Guys,
I am looking for suggestions on how to get good clean sound out of my system. I've spent thousands and it sounds worse then factory. Very disappointing.
The sound is very compressed, digitized. The bass is sloppy and inaccurate.
Installed
2014 Ford Focus Hatchback Titanium with Premium Sound & SYNC
Factory Sony AMP
JL 500/1 AMP
Kenwood KAC-8406 Amp
AudioControl LCQ-1 6 Channel Line Output Converter LOC with Equalizer & AccuBASS
Focal Access 165AS 6-1/2" 2-Way Component System (Fronts & Rears)
Massive Audio CAP4 (Capacity 4 Farad)
2 reputable Audio shops are telling me two different things.
Guy that installed it: "The issue is that I am using the factor head unit and factory Sony amp and there aren't many ways around it. Get a new HeadUnit and loose the factory amp & Navigation" Metra Online
Other shop: "You need a Bit Ten and will cost $1150 to install and calibrate, and I can't guarantee that will work but should sound better then today" In the same conversation, he was telling me he would like to Dynamat it, maybe reinstall some of the speakers or sell me new speakers and redo all my wiring at a big cost. The issue I had was that I clearly have a signalling issue and that is 90% if not more of the issue. The stuff I bought and have installed is not bad stuff. I felt like he is trying to really sell me something I don't need. For the record, I love Dynamat and have installed it before, just saying that's not the big issue with my system.
It appears the root of the issue is there is no easy clean way to integrate into the Sony factory amp and get clean sound out of it. Is that the issue and if so, what are my options?
I appreciate your help.
-TCwave
the biggest issue you are encountering is a drastic EQ curve from the OEM amp. the LCQ is very limited in the adjustments it can make on an EQ curve. that was a bad choice to start with, the guy that installed it should have stopped you right there. the hardest part about defeating the OEM EQ curve is tuning it to get as close to flat as possible. the BitTen can do it but all the tuning is done by a person, which means lots of labor hours charged. I'd look into a JL Audio CleanSweep DSP that can autotune. I'd personally look into the PS8 from Arc, BitTen from Audison, 360.3 from RF, and the CL-SSI and CL441DSP from JL Audio. you have to defeat the OEM EQ curves and get a full range flat response. I think the "other installer" is closer to being able to figure out the issue but that price tag is a bit much unless he is willing to do the work first but you'd obviously need to show him you're willing to pay for it.
The clean sweep does not auto tune. It wipes out the factory EQ and sets it to a flat signal not flat acoustics. It does have s few presets but nothing is measured.
Another option is to get the 4 channel amplifier and purchase 2 surface mount speakers for the rear deck and 2 for the front kick panels. Running...
I just ordered a Sony XM-GS4 amp for the Focal door speakers. The Mosconi Pico 2 powers the factory subwoofer, and sail panel tweeters. I'll post...
807
Did you consider using the PAC AmpPRO 4, AP4-CH31? It will connect between factory amp and head unit and allow you to have RCA outputs for the amps.
5
Do you have about $100 to waste? Try a cheap amp that has line-level inputs, see if that helps. WalMart carries a 4 Channel Jensen amp, for its...
8
id put in a good new deck and front speakers, forget the rears (fade to the front). then when you get a new car, take the deck and front speakers...
tcwave
tcwave
United States
The Camry
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
