2015 GMC Sierra Crew help
  • 1
BrentL
Hi all, I'm looking for some help with the design / install of a small system in my new truck. It is a non Bose with 8in touch screen. What I want to do is add a small 5 channel amp, replace the factory door speakers, and keep the stock head unit. This is a small budget build, I already have a set of Alpine spr - 60's for the read doors and spr -60 c's (components) for the front door. Will probably run one 10 in sub under rear seat. My concern is about that **** door chime.. I understand it gets even louder when you amplify it. Has anyone come up with a way to get rid of it? What I'm wondering about is if anyone has left the stock head unit powering the dash speakers, they would still add some fill but wouldn't get a louder chime right? Also, if we feed the front door speakers with the rear door source, would that keep the chime out of the door speakers? Does using the back door source screw up anything with the hands free / steering wheel controls? And last, what to use to connect the stock hu to the amp? I was thinking about an Lc7i, but open to other ideas. Sorry for all of the questions, I just keep getting different suggestions from the local shops. Thanks in advance for any help!
Could not tell you, but you may want to start by going to crutchfield and get a consensus on the 7 or so replacements they recommend. That average...
Not less power but less channels. Maybe upgraded all around Bose speakers as well.
9
I may end up buying the new CDT ES-08 Plus and running customspeakerpods.com 8" speaker pod.
23
3K
Just go by color to color. LF, RF, LR, RR are your speaker wires. Positive + and Negative ( black stripes ). White, Gray, Green, Purple in...
My issue is I already have the box (without the 10" adapter ring) so I'm kinda stuck on a 12, which isn't the worst thing in the world 😂 I had...
15
BrentL
BrentL
Fresno,ca
BrentL
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
