2022 Toyota Hybrid Camry Amp Wiring
  • 2
Silencewithin
CarAudio.com Newbie
Hey guys, looking to do a Sub / amp install in my new Camry 2 10” SA V2 D4 Sundown’s with a Sundown SIA-1750 amp. My concern is that I’m going to be over working the charging system in the the car. So my question is what the best way to wire up the system without putting a lot of stress on the system. Dual battery? Battery / Big cap? Big Cap before and after battery? I’m new to the hybrid world so it’s throwing me off.
Owning a hybrid. I too would look for more juice if I were you. I don''t see why you can't get a smaller AGM battery and use it tap off-of-that and use a charger at home to bring it back up while parked at night. Only issue I see is there is only one vent for batteries in the trunk. Maybe you can t-into that vent. Another issue is you would need to take the 12v power and either power anew amp, or running the old power would probably be very difficult because of the wiring in the car and info going to the HeadUnit in these cars. I bet that a very good auto stereo shop that does custom stereo work would know. But as usual, nothing is free. I could not recommend any shop, wish I could. If it wasn't a hybrid I would be temped to say run an inverter, but on 2nd thought the electronic alternator generation noise feeding the power would be terrible. The battery can act as a noise filter. and also as a buffer for over voltage. I think that is enough to chew on.
I'm most likely getting a 2022 Infinity QX60 next week. Like most new cars, it has the "Infotainment" system with the huge screen and all the...
Very true, however I also am having trouble finding a speaker that would appear to fit the bill, several have tweeters and a woofer, but not a sub...
52
6K
Im not a fan of S.Down, and everyone knows why. I wouldnt buy a screw from them. #1. The enclosure is everything when it comes to the performance...
26
3K
  • Locked
2021/2022 Polaris Slingshot SLR / R / SL 4 Seaters Text : ‪(612) 470-7321
Silencewithin
CarAudio.com Newbie
Silencewithin
Washington
retiredat44@hotmail.
Brendon Jenness
    May 11, 2024
RedRyder18
    May 11, 2024
