240 amp mechman alt
cdc351jeferson
austin tx
Not on here much anymore email davidcarlson1984@gmail.com
Small case gm 240amp alt . Was on a 3.5l v6 2006 pontiac g6
Alt is 8 months old. Was used for 6 months regulator went out on it and mechman warrantied it. Good as new ready to use. (They said they got a batch of bad regulators)
condition is a 9.5 of 10 only cause it was mounted and used
350shipped to your door
@double 07 ; can vouch for me altho I got a few refs
cdc351jeferson
It's on me
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
210
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
412
6
494
cdc351jeferson
cdc351jeferson
austin tx
Mzlady
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
