240 amp mechman alt
cdc351jeferson
austin tx
Not on here much anymore email davidcarlson1984@gmail.com
Small case gm 240amp alt . Was on a 3.5l v6 2006 pontiac g6
Alt is 8 months old. Was used for 6 months regulator went out on it and mechman warrantied it. Good as new ready to use. (They said they got a batch of bad regulators)
condition is a 9.5 of 10 only cause it was mounted and used
350shipped to your door
@double 07 ; can vouch for me altho I got a few refs
cdc351jeferson
It's on me
Matthew Young
8:11 AM (0 minutes ago)
to me
It will fit most 2005 – 2011 GM midsize cars with 3.4, 3.5, 3.8, and 3.9L V6 engines.
Matthew Young
(865)522-6166
1-888-MECHMAN
mlogan@mechman.com
Mechman Alternators, High Output Alternators, Built in the USA, Call 1-888-MECHMAN!
Billet-Tech Alternators, The Next Step in Automotive Charging Systems, Built in the USA, Call 1.865.522.6166!
Truck Tough Alternators | Tough Alternators for Tough Trucks 1-888-632-4626
response from mechman on asking what this will fit
bump
The 240 should be 2x40/ 2ch. rated at 11.9v. Should generate close to 50+ @14v rms. Only Rated @4 ohms bridged Mono.. Should be around 125 rms...
5
215
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
417
6
496
cdc351jeferson
cdc351jeferson
austin tx
Mzlady
