2500.1 settings with LC2
  • 3
s2thab23
I have an LC2 tapping into my factory stereo, running a signal to a Rockford Fosgate 2500.1bd, powering(for now) a 15 inch T2 2ohm sub. Anyone have any experience with the gain and equalizer settings on this 2500.1? It seems to need to be set pretty **** high to get this sub to produce, is the LC2 really dampening the signal that much?
You should be able to put the gain all the way down on the amplifier and use the line driver on the LC2 to level match it to the radio for full power, even into clipping, and get the highest S/N ratio too. I’m guessing the input gain on the LC2 isn’t set correctly.
So flat can be synonymous with bright? I assumed otherwise…shows my level of understanding. Speaking of mixing or mastering, the way it’s setup...
42
4K
Amazon has Infinity Reference 9630 Harmon refurbs on sale for $120 bucks. Compared these to several other brands and using an old NVX 2"/SB...
963
Hello new to the forum. looking for some help from the guru’s out there. i have the factory alpine 10 speaker with the 8.4 uconnnect. im...
s2thab23
s2thab23
Spokane, WA
Jcsaudio
1aespinoza
    May 18, 2024
Mr FaceCaser
    May 16, 2024
