2ch amp for JBL P660C components
  • 4
fazio93
N/A
i'm looking for a decent 2 channel amp to power some P660C components. they are rated 90W RMS but i have read they can easily handle double that power without a problem, not that i plan to push them that hard. i'm looking for a reliable amp around 150-200W RMS per channel (for some leeway) in the $100-150 range. it's been a while since i've kept up on certain brands & models so i'm not sure where to start.
btw, the JBLs are 2ohms.
thanks
if i wanted to save a few bucks while still meeting my needs, would this be just as fine:
Amazon.com : PRECISION POWER BA800.2 Black Ice Series Class A/B Amp (800W, 2 Channel) : Car Electronics
or an almost identical soundstream one:
http://www.amazon.com/Soundstream-Picasso-P2-400-Channel-Amplifier/dp/B00BMFO33W
i realize the A/B is a bit less efficient though.
i know there's good/bad amp brands and good/bad models and series within each brand, so i'm just looking for something reliable and solid.
thanks
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
121
6
359
  • Locked
NVX MVPA1 Best tiny amp Installed a bunch, but have one pushing a sealed 12 @ 2ohm in my daily beater Can bump it all day long and barely gets...
4
662
Amp
This tested well on youtube - not familiar with the brand but it is a pretty standard china build house amplifier...
5
479
fazio93
fazio93
N/A
fazio93
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
