2ch amp for JBL P660C components
  • 4
fazio93
N/A
i'm looking for a decent 2 channel amp to power some P660C components. they are rated 90W RMS but i have read they can easily handle double that power without a problem, not that i plan to push them that hard. i'm looking for a reliable amp around 150-200W RMS per channel (for some leeway) in the $100-150 range. it's been a while since i've kept up on certain brands & models so i'm not sure where to start.
btw, the JBLs are 2ohms.
thanks
if i wanted to save a few bucks while still meeting my needs, would this be just as fine:
Amazon.com : PRECISION POWER BA800.2 Black Ice Series Class A/B Amp (800W, 2 Channel) : Car Electronics
or an almost identical soundstream one:
http://www.amazon.com/Soundstream-Picasso-P2-400-Channel-Amplifier/dp/B00BMFO33W
i realize the A/B is a bit less efficient though.
i know there's good/bad amp brands and good/bad models and series within each brand, so i'm just looking for something reliable and solid.
thanks
202
406
490
  • Locked
783
Amp
567
fazio93
fazio93
N/A
fazio93
