2nd Battery/Distro Block Fuse question?
  • 3
NJTStang11
Chicago, IL
Ok, Im ordering a small second battery for the trunk and here is what I understand.
Underhood Battery Positive to Trunk Battery Positive
-Fuse 1: Usual underhood spot (I have 300a fuse under there)
Does a second fuse go near the battery in trunk from original wire of positive? (long 13ft strand with fuses 1ft away from both batteries)?
Or does it hook to battery, then power line running to amp get fused (where I think it goes).
If it is where I think, will a fused distro block with 100a AGU fuses suffice or should I get another separate fuse holder/300a fuse?
Ground Underhood battery to chassis (will be done in big 3 anyways)
Then run a ground from chassis in trunk to negative on battery.
Then run a another run of ground wire to my ground distro and to amps from there?
Just a couple clarifications before I jack anything up.
And also I dont plan on running w/ car off or anything so I dont need an iso right?
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
This works. Using a 550Watt RMS Amp. The sub is 600-1800 RMS. No Battery Draining BS. Still sounds clean and low. But DD Amp goes lower and hits...
22
NJTStang11
NJTStang11
Chicago, IL
pntbllwlly
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
