amp going into protection
  • 3
wyatt315
charlotte
my amp is going into protection with out the wires even hooked up to the subs i beleive it is because of the ground but no matter where i move the ground it wont work but if i wiggle the ground around or touch a spot of metal the subs will start booming im not sure why when i screw it down it just stays in protection but if i rub it around and find the right spot it'll play its pissing me off
Sounds like you've got yourself a nice groundloop.
Get a groundloop isolator, make sure your ground is grounded to the chassis on SANDED metal.. BARE metal, no paint at ALL.
redo your wires, like redo your ground (on bare metal of the frame) or just do a run to your negative on your battery like your suppose to
Make it look nicer. Carpet it up with black. It will look like a speaker. The wood look is not good at all. Don't look too professional. What...
39
6K
Not much user serviceable about an amp powering up into protect with nothing else connected. Send it back for repair/exchange or whatever they do...
Thank you for the info and advice. I really appreciate the help. I will double check my wiring tonight or tomorrow.
20
4K
wyatt315
wyatt315
charlotte
jamesw
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
