2nd Battery install
  • 3
Tapil
If i was to run a second battery w/o a split charge, would it be correct to from positive to positive? with a 30 fuse within 12 inches of each battery? Then giving the new battery its own short ground?
Of course battery 1 has the alt/engine/fuse box and wotnot attached so...
A 2nd battery for a lighter load on my alt. Having 2 batteries in parallel makes me have twice the charge power right? (depending on the bat)
yes and you can also ground link them as well as ground to frame. You will still have a 12V~ load.
also, they willbe acting as one anyways. are they identical bats? You would be better off if they where both identical and the same age...
Yeah Ive got one brand new optima yellow cap in my closet - I was going to buy two but their 2nd optima was a smaller one, they will have more instock friday.
And I thought running a really long ground wire was a bad idea? I guess since its 0 AWG it doesnt matter?
If unibody car, should run ground from battery to battery.
That does make more sense but then we are talking a 16ft ground wire, isnt a long ground a bad idea? Or im guessing since it goes to the battery it doesnt matter?
get matching bats. it is not bad idea with long ground to link bats. but you still have to ground them both at their locations. I did this in my car. I ran ground from front to back and connected the batts together and still grounded them to location.
Yes Frame is best if second battery is in the rear.There are plenty of bolts and even unused holes in the Frame that can be used for an excellent...
7
Just want a give an update. I ended up trying a capacitor to see if it would work before spending on a battery. The capacitor does work, the...
9
This works. Using a 550Watt RMS Amp. The sub is 600-1800 RMS. No Battery Draining BS. Still sounds clean and low. But DD Amp goes lower and hits...
22
Tapil
Tapil
West point, Va
subzero
Doxquzme
    May 19, 2024
Dylan27
    May 19, 2024
