30hz too low for 4 sav.2 8s?
302yota
i just picked up some 8s this weekend now im working on a design for the box...my main goal is to pound the lows, this probably will not ever see a meter...I just want to move as much air as possible, maybe get a mini hair trick out of it...they will be powered off of a saz3000...so far im thinking 4cuft at 30hz....with 18sq" of port area...is that too low for these 8s?...they will be going in my jeep patriot
They will unload and die a horrible death in that much air space on that much power. And, 18in² isn't enough port.
Two cubes and 18in² per cube would be fine and no, 30Hz isn't too low for them.
my final design came out to be an S shaped ported box...subs up port back..3.3cubes at 32hz with 18.2" of port area per cube...i really wanted to tune lower but my choices were limited..i have got to fool with these subs yet, so im not really sure what to expect
They get loud and low but probably won't move enough air for a hair trick. Better chance with two 15's or bigger. More cone area on 2 15s.
I run the 8v2s and love them though. They take a beating
That should be fine.
I tuned to 26hz with my 4 sa8s
The one and only mtx amp I've run was like that (it was black with the fake chrome platistic badging back in '01 I think) the first time I made a...
41
4K
You need something more like a pro audio woofer. You want a really light Mms with a lower Fs. Idk how much loudness vs range you want, but a...
14
16.6 is way too high. That will destroy an AGM battery. What alternator brand did you use? Sounds like a voltage regulator issue. Are you...
4
I had 2 ab 15's in the same size sealed box (4cuft) and it was loud but these sql-15's are on whole different level 🤣
302yota
302yota
rockingham, NC
302yota
