4 6.5" Massive Audio Hippo XL subs enclosure
  • 5
Boomin_tahoe
Hurtin' feelings errrday.
15,658
230
WA
Was given an opportunity for a local guy to build him a ported box to fit under the rear seat of his SUV. Modeled it up in Sketch up and got done with it a few days ago. Still gotta cut the mounting holes as I'm waiting for true measurements from the guy once he gets the subs.
"Sigh"... Looking at that green grass means a temperate climate... and makes me "green" with envy at the moment... lol... its forecast high of 112 today here.
How much amplifier power is the guy going to be using?
Did you design the enclosure or just build it?
Port looks very small, why didn't you make it the full height?
Thought it looked smallish myself but don't know anything about designing. He got the design from someone else, I just built it....and noticed 2-3 dims that were off. Imma tell the guy not to go thru with him again. Wasn't even given a 3-d drawing, barely any pics showing what it will look like. Supposilly, the port is tuned to 35Hz but it's 10" in length. I hate to see the actual tuning from a few gurus on here and have the guy dissapointed and build a new one.
I haven't asked him what amp he's going to power them with but I will when he comes and picks it up. I def didn't design the enclosure. I don't know if I should release the actual dims on here and have someone look into the specs on it and let the guy know he'll be disappointed with it or wait until later then he'll tell me it sounds like crap.
if the airspace is high, with a small port like that it should be 35hz just might run into compression when you put a lot of power onto it.  If its a low powered setup then small port area is okay.
  • Locked
hello mate, text me +1 (706) 300 5660 for quick response, if you need the Massive audio 15" dmx stage 2 for sale at a secondhand price, stay safe
  • Locked
Hello all, I am new to this forum but have had no luck on ebay/gumtree/fbmarketplace regarding trying to shift my aftermarket car audio setup. My...
It only works if you send rca signal through it to your amps.
The siq amps are Sq beast as well. And much cheaper. Made by s&I in Korea iirc
104
Boomin_tahoe
Boomin_tahoe
WA
THATpurpleKUSH
slater
    May 2, 2024
slater
    May 2, 2024
