4 channel amp for FOCAL P165V30?
  • 4
If you want a relatively high end amplifier that's also affordable, consider the Sounderstream Reference amplifiers. These use very good internal components, but they are Class A/B or Class A/B related, so they're pretty big. If you want a high end Class D amplifier, consider Alpine PDX F4/F6 or JL HD. If you want an affordable decent Class D amp, see Alpine MRX-F65. If you want something very cheap, perhaps a PPI Black Ice 4 channel (there are several models).
JBL MS A1004 seems like a nice little amplifier, but a little overpriced for what you get. The main "enhancement" relative to competition is that it has some limited DSP capability built into (active crossover, time alignment, and maybe some other things.. I'd prefer to get a Pioneer DEH-80PRS + a random 4-channel amplifier for the same price).
about the same as the ppi, the ppi has a better crossover though
They don't use the same components internally. Hertz is better IMO, but it's also a lot more expensive. _massive power_. In bridged mode it does 2x600watts at 4ohm. In that price range, I'd consider a JL HD amp just to see what's everyone is raving about.
I meant same design
Thank you for your reply and I hope I can have a good sound quality price of roughly $300-400 can also choose the class D power amplifier is because it is very small
Excuse me, I said this a few power amplifier which voice quality is better?and mini amplifier
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
411
6
493
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
864
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
899
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
chenzhuops2
chenzhuops2
Los Angeles, CA
chenzhuops2
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
