4 channel amp install HELP!#2
  • 3
iivan
ok i connect my speaker like i was told
i figured the remote cable isnt too important so i did a Y connection to my 2nd amp
i turned on my car and it made a hard radio static noise
turned it off
turned it back on and it shut off
and it kept doin it
you think i should connect the amp st8 to the speakers?
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
120
6
358
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
738
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
830
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
iivan
iivan
United States
keep_hope_alive
Doxquzme
    Jun 1, 2024
1aespinoza
    May 31, 2024
