4 channel amp with only one rca output from HU
  • 6
Look for this, its called a Y split. Cheapest route other than buying a new HU. But will you loose front and rear fade.
I probably should have clarified. The headunit has both left and right outputs for the front channel but theres only one set of them. The amp has two sets of left and right inputs, one set for the front and one set for rear. Unless I'm just confused on where to position the y splitter.
My cadence 4 channel has a switch on it that allows me to use one set of rca's rather than the traditional 2 sets for all 4 channels maybe other amplifiers use the same technology.
^^ depends if you have them split behind the deck or if you have them split at the amp. split at the amp is a lot easier and then you'll only need to run one set of rca's to the rear of the car
146
381
10
766
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
841
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
KilluminatiDre
KilluminatiDre
Japan
Side Show
maylar
    Jun 2, 2024
    Jun 1, 2024
