4 ohm amp but 8 ohm speakers?
  • 1
teenycar
So I have a JL Audio 450/4 slash v2 amp. I'm using it to power my front stage which is a 4 ohm passive system. The amp sends 150 amps on channels 1 and 2 and 75 watts on channels 3 and 4. I want to use channels 3 and 4 to power a pair of 8 inch peerless SLS drivers but they are 8 ohm. I could wire them in parallel and bridge channels 3 and 4, but I'd lose the ability to balance left and right, but maybe that wouldn't matter since it is just rear fill dedicated midbass. Bridged it would send 150 watts at 3 ohms. Currently my rear fill is a passive 4ohm setup, but if i just ran the peerless 8's then I figured to run it active off the amplifier. Is there a way to keep the tweeter rear fill and run it passive with an 8 ohm driver driven by a 4 ohm amp.? Anyone got a way to wire these drivers to my amp?
It also lowers the amps efficiency and raises the current draw.
5
688
Hell... Run It.. You will be ok @ that Ohm load(2.67). Just dont go below 2ohms and you will be fine. 2ohms is the lowest stability of that...
5
Thank you for your advice, everyone. I feel much more confident going forward. You guys are great (y)
17
teenycar
teenycar
Redlands, Ca
teenycar
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
