4 ohm sub measuring 2-2.5 ohm. Amp going into protect.
  • 7
Psychojic
CarAudio.com Newbie
Last week my sub fell over on its face when I took a corner too fast. Afterwards my amp would go into protect when I turn up the volume. I checked my sub for any damage and couldn't find any visually. I measured the ohms and it reads 2-2.5 ohms at the sub terminals. I also measured the speaker terminals (bridged) at the amp when it would go into protect and the ohms would shoot to 300 ohms for a half a second, not sure if thats normal or not. I temp fixed the issue by connecting the speaker wire to just the left side instead of having them on the bridged terminals. Both the amp and sub are about 13 years old. Any help or ideas would be greatly appreciated. Thank you!
Amp: JL Audio JX360/2
Sub: JL Audio 12W1v3-4
I like to make a False floor out of 3/4" Plywood or the like. Cover with sub box carpet and secure on the ends or where ever you can screw it down to the metal of the vehicle.. Then with subs out of the enclosure, secure the enclosure to the false floor inside the enclosure, put subs back in and generally pretty secure. Gives you something to mount your amps to as well and other gear/
That's how I'm set up too...made it real easy to drop a 2nd battery in and block it off so it can't move
Right On man. Its not as expensive to do as most think and doesnt take rocket science to do with minimum of tools, and its so much better than the Cardboard inserts that Car manufactures Cheese out on, and looks a hell of alot better than those dammned L brackets that tend to give eventually from road vibrations ect. and are an Eye sore to me
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Sure we need to grow up, ok. I gave you the exact answer then you blew up on me saying I was wrong. Time for self reflection bud. Cant take...
20
3K
It also lowers the amps efficiency and raises the current draw.
5
379
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
240
Psychojic
CarAudio.com Newbie
Psychojic
Colorado Springs
Infidel305
Brendon Jenness
    May 8, 2024
Doxquzme
    May 8, 2024
