4 skar evl 15s on a taramps bass 5k..
  • 2
Chadwic1
CarAudio.com Newbie
Hi guys, new here...names chad..
So having some issues trying to decide on keeping my slot port or going areo port..wanna do a 10" possibly 12".. my box it 36w 19h 36d... double baffle, double bottom, an 3 sides are tripled 3/4 mdf.. back side where port is, is doubled. Soon to be tripled. Yes prolly over kill but damn it has an amazing sound. Im not to good on port volume an tuning. I wanna tune around 33 32hz sub calls for 3.50-3.75 volume an 32hz tuning.. now im terrible at doing this can i please get a little help?? Anyone out there know about what id need to make this sound better?? Car audio is never ending. Thwres always more to add tweak, twerk 🤣 etc... id really appreciate it...im running 4 skar evl 15s d2 to 1ohm on a taramps bass 5k, will be replacing soon to the bass 8k, or even a banda 8k havent decided yet. If dont mind an you know the math on this. Please send me a msg or comment on the blog..thanks guys an also if need any help with anything I've been into car audio since I sat in my friends car 16years ago... a Honda crx 6 15s, pretty much walled huge box.. blew my mind an been hit ever since..🤷‍♂️🔊🔊💜🖤 ill send a little clip if can of it doin 18hz to 24hz.. i have a gmc arcadia. 08, big 3, 6group 27 batteries.. before you say anything I am gettimg 2 45ah limitess lithiums soon to replace that.. it does hold voltage well.. but know I could do better.. have a high output 350amp alternator..re audio 500.4 on my mids an highs.. alpine single din.. im ol school 🤷‍♂️ again thank you if can help me out I just know it could sound better if use these ports. I cant get to the recommend volume or tuning with out making the box higher.. 19 to like 25"
  • received_794104724719741.mp4
    7.2 MB
WinISD does a good job letting you "see" the tuning and response of your box and should tell you how big your port needs to be. You may have to have a round port tube that sticks out of the box to achieve the tuning.
Just make sure you don't buy a cheap eBay alternator. They advertise a higher max output but almost always put out less amperage at idle than your...
27
3K
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
7
558
11
934
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
6
Recoil 2500.1 $179 2500 x 1 @ 1 ohm. Make sure subs are the dual 4 ohm version. If you don't want that much power, get the Recoil red1200.1 for 1...
4
Chadwic1
CarAudio.com Newbie
Chadwic1
north carolina
Seth F.
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
