im lost on what to power my skar rp 4500 and evl 10's
bubs
CarAudio.com Newbie
12
houston
i have a 120 amp alternator it was powering it fine til it wasnt lol. but i also have a tiny battery in my car i know i need to buy another battery to put in the trunk but im more lost on what amp alt to get, ive been reading for hours and never a clear answer varying from full on blow ur month pay on a 1 of a kind alt **** yeaa!! to just see what happens with a new stock one. id rather not buy one and regret it after 2 weeks and spend more money on a new one so looking for some advice to prevent me from making a mistake.
How many watts is your system?
it says its a 4500 watt amp but ive seen them go to 6k+ so lets just say 4500 on the amp. each sub is 1k i have 2 was planning on throwing 3 of em in there but probably wont anymore since i didnt think my power supply situation thru. im running everything 0 gauge
Yeah. Lol. It’s right in the title.
I’d get a 300 amp alternator ant least, and a good 2nd battery. Thats probably still under powering. I recently did a dual 18 inch sub build. He was running 3500 watts. He had 300 amp HO alternator and a lithium bank. Voltage stayed right at 15 volts at full tilt.
I'm running a 320a alt with a 100ah agm in the bank for my smart3 my voltage only drops into the 13's if I start playing a few tracks of techmaster peb back to back at full tilt
see for my car tho ive only seen alts that say "200+ @ 1500 rpm" and there $600 ive yet to see one at 300 if i were to get like 5000 watt battery u think a "200+" alt could charge both my batteries.
Mine is a J&S alternator...check mechman (others will know more companies for ho alts). You might have to actually call and ask about your car though
definitely will. i mean regardless tho ima spend 700 on that alt. u think just running 2 200 amp alternators would be more worth it? i have no idea how hard thatd be tho
For that you would need a dual alternator bracket, and you would also have more drag on the belt. For the cost of two plus that, you can find a larger single alt.
To me.. It looks like the Allen head screws are in the terminals on the speaker inputs on the amplifier. The negative looks like its in there and...
5
In order to answer your question, I would need to know what model (e.g. SW4200, SW7524DVC). Also, are you looking to make a ported box or sealed?
Ok. we have a way to move forward so let's get to the shopping list. I wanted to do this yesterday but I had my ass chained to an o-scope all day...
21
Run the biggest AGM you can under the hood, the parallel runs to one of these - should be everything you need and then some...
5
399
bubs
CarAudio.com Newbie
bubs
houston
TheBigPilferer
winkychevelle
    Apr 27, 2024
audiobaun
    Apr 27, 2024
Latest topics
