4 Skar VD-8D2 Subs in a single cab 1997 S10
  • 1
Atongo
mexico
Hello everyone, please i need some help here with one question, i'm doing the box for four 8" VD series, what do you think about this box? or what measurement do you recommend me for this subs? I don't know how put a picture but is a wedge box and the measurement is:
Width=51 inch
Bottom depth=7 inch
Upper depth=4 inch
Height=18 inch
This box give me 2.05 Cubic Feet and this are the woofers specs:
Sealed : 0.25 ft^3
Ported : 0.5 ft^3
Displacement : 0.07 ft^3
Mounting Depth : 3.94" (100mm)
Outside Diameter : 8-3/8"" (215mm)
Cut-Out : 7.3" (185mm)
Thanks for the help and greetings from Mexico
Rolando Guzman C.
Well they fit!!
Ive doubled up 12 ga many times for sub wiring.. even 14 ga for speaker wiring. Its OFC and it should do great and save you some money since you...
492
889
I had two Skar amps (4ch & a monoblock) go bad within a year. Post #2 is an excellent recommendation.
Atongo
Atongo
mexico
Atongo
