American Bass XFL's in a Sealed Enclosure??
  • 5
FadedSpy
I've currently got two AB XFL 1244's in a 4^ft box tuned to 34hz. They're being run off of a VFL 150.1 and boy are they nasty! Problem is that I've got no trunk space now so I would like to build a smaller "Sealed" box. I know i won't be as loud and I'm ok with that. They are more than enough as it is, maybe it'll tone them down a bit. I listen to a lot of Alternative and Rock that doesn't sound all that great with the current box.
I know that AB recommends only putting them in vented enclosures so they're aren't any specs for a sealed box so I'm not sure if A) They'll even sound good in a Sealed Box or B) If there is an exact size of Sealed box to make them sound Optimal. I was thinking about 1.5^ft per chamber Sealed but before I go off and spend money building a box I would like to know what you guys think?
I could actually build another vented box with more precise measurements and gain about 8" in my trunk which would help but fIf I can get better sound quality from a sealed box then I might go that route.
Wacha think?
Or consider selling or trading them that's a little more sealed friendly, such as some of the FI subs, or perhaps IA Flatlynes.
I built a box that's about 2.75 cubes common chamber just to test them in. I plan on building a more trunk space friendly box later on but I wanted to see how these performed in a sealed enclosure. Next box will be 5 cubes @ 35hz If I build it just right I should be able to keep 1/2 of my trunk free. I will have to do it using Aero Ports or PVC which I've never done before so I'm not sure how to even calculate all of that in Torres like I have done in the past using my Slot Port Enclosures
Yeah I had torn one down and used my digital calipers to measure coil size ID & OD and winding height and spiders all had it written down and had...
4
I have 2 of them in around 2.5 cubes per sub, tuned to around low 30s Hz. I think.its tuned a little low. Really low frequencies hit thick and...
4
Yes, they are definitely beefy. I beat the snot out of this one to find it's limits and it took it rather well. For the abuse I put it through and...
FadedSpy
FadedSpy
Sioux City, IA
FadedSpy
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
