4 sub's, having a problem with 2
  • 2
beartoe
I have four kicker comps on 2 900 watt 2 channel amps. I have them split off one power wire with a dist block. Two of them work fine on one of the amps. On the second amp, when one sub is connected, that one sub works fine but when I hook up the second sub on the second amp, both subs move but put out no bass. I have tried bridging the amp as well as running them in parallel but it does the same thing. Is there something wrong with the wires or amp or subs? The second amp is new and so are the sub's connected to it. Any help with this issue would be greatly appreciated.
thanks DB, that definitely helps swallowing a $300 price tag 😂 these would essentially be running midbass for me too
12
247
What is your budget? With being exposed to Rain.. I would recommend looking at a marine grade SAS Bazooka for the sub stage
394
Don't forget Hoffman's Iron Law. You can have 2 of the 3: low end, efficiency/sensitivity or small enclosure size...
4
503
In that airspace you could go ported with th Si SQL 12@$369, hands down the best option in a 1.41 ported box. With 1000 watts RMS and 92 db...
16
821
One or two, they are still subwoofer outs and are mono summed signals from both left and right. Even the 2 RCA subwoofer pre-outs on the 2nd one...
530
beartoe
beartoe
Baton Rouge,LA
beartoe
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
