First box? Band pass boxes are designed for a very narrow band of frequencies and are MUCH more difficult to design and build, In your case, I would not entertain the bandpass option whatsoever - read:
"In general, band-pass subwoofers are highly efficient and reproduce deep low frequencies
within a limited bandwidth. While a
great deal of care is required in the fine-tuning of such designs, the resulting acoustic level increase can be up to 8 dB. Larger bandpass enclosures will have a smoother and deeper frequency response than a smaller bandpass enclosure but
not as smooth as sealed or ported enclosures. They
can be much larger than the sealed/ported enclosures if you are trying to pass a wide band of low frequencies
What you gain in efficiency is lost in bandwidth. According to what I found on that sub, it's a good candidate but I would not venture down that path unless you have a professional design the box. Chances are the box is going to be quite large too. possibly 5 to 6 cubic feet.
As for the construction of a ported (bass reflex) enclosure, in your trunk, whichever way you do it, the port works best (acoustically couples) with the subs when they are on the same baffle, regardless of whether they are up, down or turned around.
As for the Camry, if you remove the rear deck speakers and cut a bit of the sheet metal out, aim the subs and the ports upward would be my preference (make a false cover out of 1.4" hardboard with acoustically transparent material) to covedr the package tray. Use the rear doors for fill instead. I have to admit, not a ton of experience with trunks - I buy hatchbacks for that reason!
