5 1/4" speakers with neo-sym motor
  • 6
brmcm15
Oh lawdy!
at partsexpress for $28.45
going to buy some to put in factory spot so i can sell the car.
look pretty nice to me
Dayton Audio's compact aluminum cone drivers demonstrate the latest advances in high-excursion design processes. An efficient, low-distortion Neo-Sym motor is combined with a rigid yet lightweight aluminum diaphragm, yielding impressive high-impact audio reproduction. Perfect for single point-source applications, or combined in multiples and line arrays. Specifications: *Power handling: 40 watts RMS/80 watts max *VCdia: 1" *Le: 0.72 mH *Impedance: 4 ohms *Re: 3.7 ohms *Frequency range: 54-8,000 Hz *Fs: 54 Hz *SPL: 85.3 dB 1W/1m *Vas: 0.36 cu. ft. *Qms: 6.59 *Qes: 0.74 *Qts: 0.66 *Xmax: 4 mm *Dimensions: A: 5-1/2", B: 4-3/4", D: 2-1/2".
* Extended-range 54 Hz to 8 kHz performance
* Rubber-edged aluminum alloy cone
* Large excursion capability—4 mm Xmax, 20 mm peak
* Self-shielded Neo-Sym motor structure
* 1" 4-layer underhung voice coil with polyimide former
* 40 watts RMS power handling
they sound pretty good, but i dont have my tweeters(PG RSD's) in cause i lost them somewhere //content.invisioncic.com/y282845/emoticons/crap.gif.7f4dd41e3e9b23fbd170a1ee6f65cecc.gif i have to buy new ones.
but man do these things move!!! ill try and get some vids of them up tomarrow. But overall totally worth what i paid for
If the JBLs have tweeters built in, disconnect two of the tweeters and the 4 Ohm tweeters will be their replacement. Then connect one combo on the...
243
Out of the amps you mentioned Kenwood 805 hands down best bang for the buck. You won't be able to tell any difference from 5x7 to 6.5. You may...
200
In the past 10/15 years. I feel like the best sounding/performing speakers Ive ever heard to date were some Hertz MLK & Mille series running off...
368
brmcm15
Oh lawdy!
brmcm15
Macomb, Michigan
brmcm15
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
