Need New 6.5 Coax's
  • 6
TRiCK
Maine
Budget is around $100, feel free to find something cheaper.
Try to stick to stuff on OnlineCarStereo.com because thats where I do most of my shopping.
I had ordered the TMA 6.5's but they went out of stock.
How I would approach it is install your new amplifier and start using it. Install a voltage gauge and if you see your voltage lowering then add...
4
166
While most Asian and African markets will identify Honda's small hatchback as the Jazz model, most Western regions will know the same model as the...
121
The Kappa's have a high sensitivity rating of 93 db so the X802-5 would be fine. A good high sensitivity 8" sub in a properly sized box would fit...
468
Yup , the dsp should have input sections, it may have one for sub? Hu to dsp. Dsp to amps, amps to speakers. Probably help you to draw this all...
361
TRiCK
TRiCK
Maine
Hoodlum007
Dylan27
    May 18, 2024
Dylan27
    May 18, 2024
