5 channel amp vs multiple amps?
rugbeanz
so im installing 4 speakers and 2 subs in my car.
what are some pros and cons of a 5 channel amp to power all of them or a mono amp for the subs and a 4 channel amp for the speakers.
2x 6.5" @ 50 RMS 4 OHMS
2x 6x9" @ 60 RMS 4 OHMS
2x 12" kickers 150 RMS 4 OHMS
My suggestion is Massive Audio nx3 it's a 3 ch amp the sub ch alone puts out 800 rms which can be split to run two subs. I have this amp and brand new shipped to my door it was 150 bucks.
Running multiple amps depends upon your budget too if you have one.
Run a 5 channel
I love mine
The only reason to get a mono after a 5 channel is if you want more power
And even then you still have a 5 channel to use as a 4 channel!
i would only opt for the the 2 amp setup if you ever plan on upgrading by getting amps with a little more headroom on the wattage. However that's obviously gonna be more expensive than the 5 channel option. However if you're gonna stick with what you have than 5 channel is a very solid look
speaking of multi amps what about the shaker 1000 in a mustang it runs Four 4ohm mono amps for two 10" dual 4ohm subs, one amp per coil. what do you guys think of running the four amps in parallel or in series to power one sub? is that even posible? what would the ohms be? and could it power a dual 2 ohm sub that ive got laying around? dual 2ohms can be wired to 1ohm or 4ohm i think. i know this is a bit off topick but im new here and i couldnt figure out how to start a new thread:emb:
Hello Everybody, Due to an incorrect install from a local stereo shop one the channels of my Alpine PDX-F4 is no longer working. I was told...
No need to bypass the amp. Most use an LOC that takes the full amped signal and turns it into a flat RCA level signal. Here is the newest I have...
477
6
517
Pretty much. It's just a nice kit. A solo rite Scarlett 2i2, XLR mic and a loop back cable are my next purchases so I can get accurate phase...
10
898
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
922
rugbeanz
rugbeanz
Minnesota
Boomin_tahoe
