5 channel amp
Johndull96
Hello,
I am searching for a 5 channel amp. I'm not particular about the brand, as long as I can find some information on it, and verify its an amp worth while. I am looking to spend
I'm located in Annapolis Maryland
I am also looking for 4 6.5" coaxial or components
Thanks
John
Hello, I am searching for a 5 channel amp. I'm not particular about the brand, as long as I can find some information on it, and verify its an amp worth while. I am looking to spend
Thanks
John
I may have what you are looking for it's a helix dark blue 5 chan. Amp
■ Cont. power at 4 Ohms (13.8V): 4 x 75 + 1 x 350 Watt
■ Cont. power at 2 Ohms (13.8V): 4 x 110 + 1 x 550 Watt
■ Cont. power at 4 Ohms bridged (Channels 1-4): 2 x 220 Watt
■ Cont. power at 1 Ohm (Sub Channel): 1 x 700 Watt
■ TIM distortion:
■ Signal to noise ratio: > 93 dB
■ Bassboost : 0-18 dB
■ Setting range highpass : 10 Hz-2,5 kHz
■ Setting range lowpass : 40 Hz-4 kHz
■ Regelbereich Bandpass : 15 Hz-4 kHz
■ Setting range bandpass: 10 Hz-30 kHz
■ TIM distortion:
■ Signal to noise ratio: 200 mV - 5 V
■ Fuse: 1 x 100 A
■ Input impedance: 10 kOhm
■ Dimensions (HxWxD) mm: 64 x 282 x 570 (2.5" x 11.1" x 22.5")
■ Weight : 7.7 kg (17lbs)
[quote name='Johndull96']I just wanted a 5 channel due to the ease. What do you have to sell, and pricing? As this is one of my first setups I'm pretty open. @fasfocus00[/QUOTE]
got an Alpine 500 watt mono, Kenwood 4 channel. the Kenwood is really small so it can be hidden if needed.
I recommend the Massive Audio NX5
It is outta your price range but the amp itself is a small footprint compared to other mainstream brands. It's got a lot of power...not to be fooled by it's size.
I can sell you a nice Alpine 5ch for $170 shipped...Its an old school Japanese made not todays China junk
Most of today's popular brands are made in China.....and people use them. Still think they're junk?
I have an Elemental Designs 9-5 with a bass knob if interested in great shape,a little more than your asking /budget, but a great amp.PM me if wanting fresh pics and price shipped.Thanks
I have a Memphis Big Belle that is being repaired at Ebbco right now. It should be done shortly, and will be for sale.
Depending on repair price I will be asking $275-$300 shipped
331
461
10
841
It is Opel (Vauxhall) Astra J 2011 model, I change the HU to Kirinavi 10 inch screen. The factory speakers are Infinity and would have come with a...
884
Okay, I'll bite. If you're going to get rear speakers, get the same ones (model type, doesn't have to be the same size) that you have up front...
Johndull96
Johndull96
Annapolis, MD
zapcoaudio
