.5 ohm sub on 1ohm amp?
pclayk
Im new to this but ive got a soundstream splx 12 quad 1 ohm sub on an autotek mean machine m4000.1d amp. I was thinking about getting a optidrive 1233d sub but it runs at .5 ohm i think but my amp only goes down to 1 ohm. Would that be okay or should i just stick with what i got? Thanks for any help you can give //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Do not put anything lower than a 1 ohm total load on a 1 ohm amp. Given the choices you presented - stay with what you have.
FYI:
Your SPLX 12 is a dual voice coil, 2 ohms per VC sub and can be wired as a 1 ohm or 4 ohm load
The 1233D is a dual VC, 1.2 ohm per VC sub that can be wired as 0.6 ohm or 2.4 ohm load
Your amp is rated down to 1 ohm, so running the SPLX at 1 ohm is your best choice IMO
FYI:
His splx comes in dual AND quad vc's "FYI". The quad 1ohm can be run at .25, 1, and 4 ohms using a single amplifier. I would stick with the splx, or sell it to me : )
You *could* run a 1 ohm amp at half ohm depending on your impedence rise but with music, the amp could randomly protect or randomly go poof lol.
Thanks - didn't realize they had a quad VC version. Same conclusion though - stick with SPLX wired to 1 ohm. Cheers.
Hello I'm happy to have came across this forum as I'm hoping someone will help with this little bit of confusion I'm having and maybe save me some...
Sure we need to grow up, ok. I gave you the exact answer then you blew up on me saying I was wrong. Time for self reflection bud. Cant take...
20
3K
It also lowers the amps efficiency and raises the current draw.
5
683
pclayk
pclayk
Paducah, Ky
Jepalan
metalheadjoe
    Jun 5, 2024
Dylan27
    Jun 5, 2024
