.5" mdf for a single 8" sub?
evil_lies
Texas
I just got a quad cab Dodge Ram and I want to put a small sub in the storage area under the back seat. I'm trying to keep the box compact. Would .5" mdf be ok for a small sub or will it fall apart? I'm looking at a Tang Band W8-740P. I'm not set on that sub though. The tang band would only be fed like 300 watts.
If it’s put together well and sealed really good it should work ..look at factory enclosure they are usually if not always thin plastic ..a bazooka tube thin plastic ..the 1/2” is way thicker ...than those ..now the 3/4 would be better
Cool. I know I'm really only saving .5". I'm haven't measured how deep I can go. It has a fold out floor that I would like to keep so if I want to keep it as small as I can.
Fiberglass is the way to go with the storage portion. I use the FoxBox in two of mine and I cannot complain. I had sealed setups previously and they were underwhelming.
Double up on the 1/2". Even a little power to a single 8" enclosure, your gonna find it difficult to put screws thru due to the board thiness vs. 3/4".
Damn, those Brickhouse subs are beefy! 4" coil and big power? Yes please!
10
just use riv-nuts or clip-nuts, made for blind fastening. some window weld should hold the ring on there pretty good..... being 4x6, you could...
4
I say go for it. Just add some kind of bracing to the bigger panels. Some old home speaker boxes were made of 3/8" mdf. Maybe not even mdf, some...
Yea. That's what I did. I mixed the glue with the dust from sanding and fill in the bigger holes. Then filled the rest with wood filler..works awesome
9
3K
evil_lies
evil_lies
Texas
Boomin_tahoe
audiobaun
    May 19, 2024
1aespinoza
    May 19, 2024
