50 watt rms headunit
  • 2
Are there any doubledin headunits (preferably touchscreen) that put out 50 watts rms? and if so can anyone provide any suggestions?
I don't think so unless that new stinger hu is. I'd look into alpine with the add on 50x4 amplifier. Easy to hook up I think they might even mount to the half chassis dd units. Seems like I seen a video of someone doing just that on YouTube iirr.
DJ subs are designed for efficiency, car audio subs are designed for low end in a small space. So above ~50hz the DJ sub will kill a car audio...
7
Set the voltage to 20 volts via DMM and it will equal out to around 100 watts. https://www.the12volt.com/ohm/ohms-law-calculators.asp#voltage
4
He wants to strap the amps to double the output to one sub. Some amps allow you to "couple" them. This allows you to wire up the one sub powered...
5
You can wire those subs up @8 ohms if they are both SVC4 ohm subs,and that amp will run fine after being tuned properly...
4
Aeris
CarAudio.com Newbie
Aeris
Vancouver
fithwheel
GoldCountryCA
    Apr 26, 2024
GoldCountryCA
    Apr 26, 2024
Latest topics
