6.5s off of HU power- Recommendations?
I, too, am in this same position. Don't really want to add an amp so I'm looking for a pair of decent components. I've been looking at the alpine type s, boston acoustics, and a few others. I'd ideally like to spend around $150 or less. Would you all recommend the same speakers?
I added the Rainbow SLX265 to my list if options, even though it was out of my initial price range. As mentioned above, I also considered the SL165 coaxials, but I'd rather keep the tweeters high in the doors. I hate wiring (I spent enough days doing that in my younger days doing my shadetree installs) but I also hate paying someone else to do it, and I don't really trust that I'll get the install that I want.
Even though they break the original budget, it might be a better option to wait until the weather warms up and just add a small amp (I have an old RF 100a2 in the garage) and go with components, then upgrade my amp later when I upgrade my substage. I may even go with the SLC265 if I go this route, but the SLX would be better if run on HU power in the meantime.
I have read about this, and honestly the installer did nothing wrong. It's the newer vehicles that have the automatic engine stop/start (instead...
982
6
83
Any indication that a loose wire may be the issue? I'd start by checking all the +/- connections to see if one has come lose or is starting to...
Disconnect the RCA's or hi-level input to the JBl amp. turn the system on, If the noise continues, it's a ground or noise issue with the amp.If it...
yall. I unplugged the radio harness and the antenna and plugged it all back in and it works. I guess its fixed… suppose it was the head unit...
812
phenryiv1
Custom user title
phenryiv1
Martinsburg, WV
phenryiv1
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
