73-87 C10 Chevrolet single cab ported box by CSCStang
  • 1
wanderer1
Laughlin
Built for pops and fit perfect until he did some upholstery work. Set up for Tang Band 1139si tuned to 35hz with Aero port. Woofers are not included since they will be reused unless price is right, these are neo magnet and $95 each. This box straight pounds, built with birch not mdf. Can ship for actual price, will be at the Brothers car show in Anaheim June 28th. Will be picking up new box from CSCStang at that time so may leave with him. Hard to get those C10's to pound, easy with this setup and very punchy with the 6.5s. Might fit small cut out 8's. Asking $150 or $375 with woofers
There are bluetooth amplifiers. You can just use your phone or an I Pod as the music source and not touch the radio.
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do...
Ok. I think I get it. There's really not much to be gained between charging them at say 60% and 100%. At least not on a daily system. Please...
13
2x 4 ohm coils can be wired parallel to 2 ohms or series to 8 ohms. There's many amps with 2 ohm power you can use.
686
wanderer1
wanderer1
Laughlin
wanderer1
