Relay and Reverse Input issues installing Boss BVCP9700A on 1993 Chevrolet Suburban C1500.
  • 2
tripdls
CarAudio.com Newbie
I'm replacing the 15 year old aftermarket Panasonic Bluetooth/Back-up camera radio on my Suburban with the single DIN Boss BVCP9700A . Using existing wiring harness, running wires for new back-up camera and adding front camera(parking assist). Everything works until Reverse Input connected. Radio locks up on back-up camera and sets off relay under steering column. Have to factory reset radio and unplug relay(not sure what it goes to) in order to get radio to work again. Without Reverse input connected, back-up camera will not automatically come on when shifting into reverse. (Desired effect.)
I would prob go and take it to a shop to someone that knows how to install, pay the $50-75-100 bucks so its done correctly.If you continue to do it yourself.. Id follow the direction within the manual/manuals for both camera, and HU installation. Apparently its not wired correctly,and sounds like you need to check all wiring again
That doesn't make any sense. The directions say to hook it up to the parking brake. The parking brake is engaged when the car is off. You...
17
6K
I bought a 2023 Mitsubishi Strada, known in most parts of the world as a Triton. Although it's 2023 it hasn't changed for a few years and this...
Use two sets of RCAs. One set for the Front channels and the other for Sub Output and into Rear Input on the amp. Turn off the Rear Filter on the...
5
511
The ZVX 8 doesn’t do well sealed. 1.25 cubes ported 35-38 HZ is what it will like. Very inefficient 8 and wasn’t very impressive to me, even in a...
tripdls
CarAudio.com Newbie
tripdls
Louisiana
audiobaun
Latest topics
