8 15" kicker comp D in a 91 suburban
  • 1
I am about to finish purchasing all of my equipment for my new build. 8 15" comp D sub's 4 kicker sx1250.1. I am taking the third row out and beginning my build from the second row back. My question is what would be the best way to implement the sub's. Clam shell, 4th order, 1 big port. Also I need good design ideas. Money is not really a problem I just don't really know where to start.
Yep, that will mark the third iteration of teh X series. i figured that was in the loop as they have been running out of stock on the last...
11
806
Is this a blue or blue/white wire from the Kenwood? The ACC wire is red and although that should turn on the amp, it is not the prefered wiring...
low level when using RCAs so that knob should be pushed out. The crossover turn it all the way right and use the one on the head unit and set it...
5
tallyburban77
tallyburban77
tallahassee FL
tallyburban77
1aespinoza
    May 31, 2024
winkychevelle
    May 24, 2024
