800 to 1000 watts at 1ohm
  • 5
Pioneer 8601 - Does 800+ @ 1 ohm $111 everywhere... Could even buy one from Wally World and get an extended warranty on it for $20 and abuse the F out of it //content.invisioncic.com/y282845/emoticons/smile.gif.1ebc41e1811405b213edfc4622c41e27.gif
Have ran the Pioneers in the past and not a fan. They do over rated but have an slight hiss. Most people can't tell it as most use them in trunk installs. But if you have ever run them in a hatchback or truck, you can hear the hiss coming thru the subs
so u trying for twice the rated power? or u running at 4 ohm and getting a 2nd later? idk about that sub the new sdr looks ok (bigger coil) but the jbl gtx500 is like $99 blank tested that to do over 800rms.. if u just looking for cheaper https://www.amazon.com/Skar-Audio-LP-80-4ABv2-4-Channel-Amplifier/dp/B0145XGT52/ref=sr_1_5?s=electronics&ie=UTF8&qid=1518642965&sr=1-5&keywords=skar%2Bmono%2Bamplifier%2Bcar%2Baudio&th=1 if u don't care about the few more $ i'd get the 800 or u can the get 1k lp for same $ as rp 800
when u putting to 2250 vid up?
I don't see a point in spending that price (130-140) when you could spend a small amount more and get an amp that will put out much more power? I dunno, is there a reason?
Either go up or down imo
if he planning a 2nd sub or better subs then yeah he should look tad bigger anyway (the sq 1250 is $179) but if he sticking to that 1 sub or upgrading to 1 600rms sub later he don't much more power.. i'd be worried that 400rms would blow as is..
Come on guys. Anyone ever heard of gain matching and headroom? The amp will be set at 400 to 450 watts for daily listening. If I decide to see what she will do SPL I can bump up to burp at 800.
oh yeah i understand box rise and wanting headroom, just saying keep that 2" coil in mind, if it was the vvx i'd say get the 1k.. if u just gonna stick with the 1 get the rp800 if u want maybe a nicer amp if u just want to power the sub good get the 750.. after blank reviews the sq 2250 tonite u may wanta look at the new sq amps instead..
Been looking at the Zapco ST-500XM. Wish I could find one used. If not, may just pay the $180 for a new one
meh for $179 i'd get the skar 1500 or the 1k lp for less but.. get the sq 850 $149.. blank just posted video of dyno of the 2250 it did over rated so the 850 should be good too..
Fully test it without the ACR-1. TBH it sounds like an amplifier issue. Try connecting your phone direct to the amp via a 3.5mm to RCA cable. If...
695
Looks Like I just saw a new 5 ch. amp on the CT Sounds Site as I was browsing today. Looks like the Sub Ch is 1 ohm stable to 400 watts. Might be...
  • Locked
You must post pictures with username and date (on a piece of paper, a digital version will not be suffecient) unless you have sold to at least 10...
AnthonyO
Budget Banger Connoisseur
AnthonyO
Minot, North Dakota, United States
BOOMINGRANDPA
Mr FaceCaser
    May 16, 2024
Mr FaceCaser
    May 16, 2024
