8OHM or 4 ohm
  • 2
Well Alot of this depends upon the configuration of your subs and how capable your amp is.
Are your subs DVC or SVC?
What is the impedence of each Voice Coil?
What Kind of Amp?
Just need a little more info first.
Take it easy,
-zane
Originally posted by zane:Well Alot of this depends upon the configuration of your subs and how capable your amp is.
What Kind of Amp?
Take it easy,
-zane
Oops.
StOOpid Distractions! he he!
[ 12-11-2001: Message edited by: zane ]
It also lowers the amps efficiency and raises the current draw.
5
397
What is the impedance of each set of terminals,assuming they represent each of the two dual voice coil subs (4 coils total)? How many sets of +/-...
259
Not all chargers are the same and charge and different rates. Any battery will deplete in that type of weather if you do not crank the vehicle for...
10
943
Brand new 210 shipped TECHNICAL INFORMATION OPERATION CLASSClass D NUMBER OF CHANNELS01 MAXIMUM POWER@ 12.6 VDC - 1 OHM: 3000W RMS @ 12.6 VDC -...
This is what I usually do before I put my main gear in. For my temp setups, Ill thrown in what I have close by out of my stash.
10
andrew
andrew
atlanta
zane
Doxquzme
    May 12, 2024
Brendon Jenness
    May 11, 2024
