8ohm speaker mono block amp question
  • 5
pghram1500
All, I have an older 8ohm RF 10" sub. This sub is rated at 200RMS at 8ohm. What size amp will I need to handle this. Looking for quality but price conscious amp. This is for my daughter looking to just add mono block amp to handle one 10" in a box in trunk. Not sure on size because of speaker being 8ohm. Hoping to get under $100 amp for her but nothing that is total crap.
Thanks
Edit: adding additional data.
I actually have two of the same subs. Would I be better to wire both to lower the ohm down to 4. Still the question exist what amp size to adequately power both subs then. The subs are RF RFP-1810.
Thanks
if u have 2 8 ohm subs yes 4 ohms is lots better either way u better off to go with a 2 channel amp bridged in this case, cheapest mono amp i'd recomend is ppi 1k like mine tested at 690rms @4 ohm so may do like 300-350 at 4 ohm it's decent amp but it's $159 or so.. u in the only situation that i recomend 2 channel fir sub and even low end at that., or if u lived here u could come try my autotek 1600 (probably does 200rms @ 4ohm maybe) u can get those about $79.. i can find u something (i do love to shop) but with that weird ohm man u maybe better to get a cheap package deal like ct sounds 12 and amp and box for $150., other pacages like that ain't bad for kid as long as u set gain low and tell them not to mess with amp.. https://www.amazon.com/dp/B01M3WW0UA/ref=twister_B01N7G2R1J?_encoding=UTF8&th=1
Thanks
read my last reply ppi 600.2 is about $117 4 ohm should do 300rms or 600 if u use both subs i'd do that and if u ever get other new 4ohm dvc subs wire each to 8 ohm and bridge this to them same way (1 guy here with like probably $8-10k system has 4 of these in his truck)
Thanks
Yes you'll be far better at 4 ohm assuming you have the space for the two subs in a proper box. I hate to say it but you may just do better dropping 100$ into a modern woofer and working around that, you could keep the 8 ohm subs and use them for a home theater sub project or something. Virtually every amp you'll buy today, particularly on a budget just won't make squat for power into 4 ohms much less 8. Even trying to get good power into 2 ohm isn't budget friendly territory and limits your options.
yeah u can get sundown E 12 d4 wired to 2ohm bstock for $95 get amp like mine ppi p1k $159 get 930 rms to it or get d2 wired to 4 ohm and get ppi p600.2 $117 600rms to sub if u put it in ported box i promise it'll be enough bass for her..
I went with Kenwood Exelon. Audio Control amp and speakers. It’s amazing! I’m glad I did some research before buying. Thanks guys.
618
Yes. Only thing is the leads will be encased in resin. Keep in mind that this is an assumption.
491
655
560
pghram1500
pghram1500
Pittsburgh, PA
BOOMINGRANDPA
